Brushless DC Machine
Detailed model of brushless DC machine excited by permanent magnets
../../_images/bldc_icon.svg
A brushless DC machine is a type of permanent magnet synchronous machine in which the back electromotive force (EMF) is not sinusoidal but has a more or less trapezoidal shape. Additionally, the variation of the stator inductance with the rotor position is not necessarily sinusoidal.
The machine operates as a motor or generator; if the mechanical torque has the same sign as the rotational speed, the machine is operating in motor mode, otherwise in generator mode. In the component icon, phase a of the stator winding is marked with a dot.
../../_images/bldc_schema.svg
Fig. 220 Electrical system of a brushless DC machine
The back EMF voltages are determined by a shape function \(k_\mathrm{e}\) and the mechanical rotor speed \(\omega_\mathrm{m}\). The shape function in turn is expressed as a fourier series of the electrical rotor angle \(\theta_\mathrm{e}\):
\[e_\mathrm{x}(\theta_\mathrm{e},\omega_\mathrm{m}) = k_{\mathrm{e,x}}(\theta_\mathrm{e}) \cdot \omega_\mathrm{m}\]
\[k_\mathrm{e,a}(\theta_\mathrm{e}) = \sum_n K_{\mathrm{c},n}\cos(n\theta_\mathrm{e}) + K_{\mathrm{s},n}\sin(n\theta_\mathrm{e})\]
\[k_\mathrm{e,b}(\theta_\mathrm{e}) = \sum_n K_{\mathrm{c},n}\cos(n\theta_\mathrm{e}-\frac{2\pi n}{3}) + K_{\mathrm{s},n}\sin(n\theta_\mathrm{e}-\frac{2\pi n}{3})\]
\[k_\mathrm{e,c}(\theta_\mathrm{e}) = \sum_n K_{\mathrm{c},n}\cos(n\theta_\mathrm{e}+\frac{2\pi n}{3}) + K_{\mathrm{s},n}\sin(n\theta_\mathrm{e}+\frac{2\pi n}{3})\]
The stator self inductance is also expressed as a fourier series of the electrical rotor angle. The mutual inductance \(M\) between the stator phases is assumed to be constant. Since the stator windings are star connected, the mutual inductance can simply be subtracted from the self inductance:
\[L_\mathrm{a}(\theta_\mathrm{e}) = L_0 - M + \sum_n L_{\mathrm{c},n}\cos(n\theta_\mathrm{e}) + L_{\mathrm{s},n}\sin(n\theta_\mathrm{e})\]
Electromechanical System
The electromagnetic torque is a superposition of the torque caused by the permanent magnet and a reluctance torque caused by the non-constant stator inductance:
\[T_\mathrm{e} \;= \sum_{x = \mathrm{a,b,c}} k_{\mathrm{e},x}i_x + \frac{p}{2}\frac{dL_x}{d\theta_\mathrm{e}}i_x^2\]
The cogging torque is again expressed as a fourier series of the electrical rotor angle:
\[T_\mathrm{cog}(\theta_\mathrm{e})\; =\; \sum_n T_{\mathrm{c},n}\cos(n\theta_\mathrm{e}) + T_{\mathrm{s},n}\sin(n\theta_\mathrm{e})\]
Mechanical rotor speed:
\[\dot{\omega}_\mathrm{m}\; =\; \frac{1}{J} \left( T_\mathrm{e} + T_\mathrm{cog}(\theta_\mathrm{e}) - F\omega_\mathrm{m} - T_\mathrm{m} \right)\]
Mechanical and electrical rotor angle:
\[\dot{\theta}_\mathrm{m}\; =\; \omega_\mathrm{m}\]
\[\theta_\mathrm{e}\; =\; p \cdot \theta_\mathrm{m}\]
Back EMF shape coefficients
Fourier coefficients \(K_{\mathrm{c},n}\) and \(K_{\mathrm{s},n}\) of the back EMF shape function \(k_\mathrm{e, a}(\theta_\mathrm{e})\) in \((\mathrm{Vs})\).
Stator resistance
The stator resistance \(R\) in ohms \((\Omega)\).
Stator inductance
The constant inductance \(L_0 - M\) and the fourier coefficients \(L_{\mathrm{c},n}\), \(L_{\mathrm{s},n}\) of the phase a inductance \(L_\mathrm{a}(\theta_\mathrm{e})\) in henries \((\mathrm{H})\).
Cogging torque coefficients
Fourier coefficients \(T_{\mathrm{c},n}\), \(T_{\mathrm{s},n}\) of the cogging torque \(T_\mathrm{cog}(\theta_\mathrm{e})\) in \((\mathrm{Nm})\).
Inertia
Combined rotor and load inertia \(J\) in \((\mathrm{Nms^2})\).
Friction coefficient
Number of pole pairs
Number of pole pairs \(p\).
Initial rotor speed
Initial mechanical speed \(\omega_\mathrm{m,0}\) in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
Initial rotor angle
Initial mechanical rotor angle \(\theta_\mathrm{m,0}\) in radians.
A two-element vector containing the initial stator currents \(i_\mathrm{a,0}\) and \(i_\mathrm{b,0}\) of phase a and b in amperes \((\mathrm{A})\).
Stator phase currents
The three-phase stator winding currents \(i_\mathrm{a}\), \(i_\mathrm{b}\) and \(i_\mathrm{c}\), in amperes \((\mathrm{A})\). Currents flowing into the machine are considered positive.
Back EMF
The back EMF voltages \(e_\mathrm{a}\), \(e_\mathrm{b}\), \(e_\mathrm{c}\) in volts \((\mathrm{V})\).
Rotational speed
The rotational speed \(\omega_\mathrm{m}\) of the rotor in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
Rotor position
Electrical torque
The electrical torque \(T_\mathrm{e}\) of the machine in \((\mathrm{Nm})\).
Cogging torque
The cogging torque \(T_\mathrm{cog}\) of the machine in \((\mathrm{Nm})\).
  • D. Hanselman, “Brushless permanent magnet motor design, 2nd ed.”, The Writers’ Collective, Mar. 2003.
  • P. Pillay, R. Krishnan, “Modeling, simulation, and analysis of permanent-magnet motor drives, Part II: The brushless DC motor drive”, IEEE Trans. on Ind. App., Vol. 25, No. 2, Mar./Apr. 1989.
