Brushless DC Machine (Simple)
Simple model of brushless DC machine excited by permanent magnets
../../_images/bldc_icon.svg
The simplified Brushless DC Machine is a model of a permanent magnet synchronous machine with sinusoidal or trapezoidal back EMF.
The machine operates as a motor or generator; if the mechanical torque has the same sign as the rotational speed, the machine is operating in motor mode, otherwise in generator mode. In the component icon, phase a of the stator winding is marked with a dot.
../../_images/bldcsimple_schema.svg
Fig. 221 Electrical system of a (simple model) brushless DC machine
The back EMF voltages are determined by a shape function \(k_\mathrm{e}\) and the mechanical rotor speed \(\omega_\mathrm{m}\). The shape function is a sinusoidal or an ideal trapezoidal function scaled with the back EMF constant \(K_\mathrm{E}\).
\[e_\mathrm{x}(\theta_\mathrm{e},\omega_\mathrm{m}) = k_{\mathrm{e},x}(\theta_\mathrm{e}) \cdot \omega_\mathrm{m}\]
../../_images/sinusoidal.svg
Fig. 222 Sinusoidal shape function
../../_images/trapezoidal.svg
Fig. 223 Ideal trapezoidal shape function
Electromechanical System
The electromagnetic torque is:
\[T_\mathrm{e} \;= \sum_{x = \mathrm{a,b,c}} k_{\mathrm{e},x}i_x\]
Mechanical rotor speed:
\[\dot{\omega}_\mathrm{m}\; =\; \frac{1}{J} \left( T_\mathrm{e} - F\omega_\mathrm{m} - T_\mathrm{m} \right)\]
Mechanical and electrical rotor angle:
\[\dot{\theta}_\mathrm{m}\; =\; \omega_\mathrm{m}\]
\[\theta_\mathrm{e}\; =\; p \cdot \theta_\mathrm{m}\]
Back EMF shape
Choose between sinusoidal and trapezoidal back EMF.
Back EMF constant
The back EMF constant \(K_\mathrm{E}\) in \((\mathrm{Vs})\).
Stator resistance
The stator resistance \(R\) in ohms \((\Omega)\).
Stator inductance
The stator inductance \(L - M\) in henries \((\mathrm{H})\).
Inertia
Combined rotor and load inertia \(J\) in \((\mathrm{Nms^2})\).
Friction coefficient
Number of pole pairs
Number of pole pairs \(p\).
Initial rotor speed
Initial mechanical speed \(\omega_\mathrm{m,0}\) in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
Initial rotor angle
Initial mechanical rotor angle \(\theta_\mathrm{m,0}\) in radians.
A two-element vector containing the initial stator currents \(i_\mathrm{a,0}\) and \(i_\mathrm{b,0}\) of phase a and b in amperes \((\mathrm{A})\).
Stator phase currents
The three-phase stator winding currents \(i_\mathrm{a}\), \(i_\mathrm{b}\) and \(i_\mathrm{c}\), in amperes \((\mathrm{A})\). Currents flowing into the machine are considered positive.
Back EMF
The back EMF voltages \(e_\mathrm{a}\), \(e_\mathrm{b}\), \(e_\mathrm{c}\) in volts \((\mathrm{V})\).
Stator flux (dq)
The stator flux linkages \(\Psi_\mathrm{d}\) and \(\Psi_\mathrm{q}\) in the stationary reference frame in \((\mathrm{Vs})\).
Rotational speed
The rotational speed \(\omega_\mathrm{m}\) of the rotor in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
Rotor position
Electrical torque
The electrical torque \(T_\mathrm{e}\) of the machine in \((\mathrm{Nm})\).
  • D. Hanselman, “Brushless permanent magnet motor design, 2nd ed.”, The Writers’ Collective, Mar. 2003.
  • P. Pillay, R. Krishnan, “Modeling, simulation, and analysis of permanent-magnet motor drives, Part II: The brushless DC motor drive”, IEEE Trans. on Ind. App., Vol. 25, No. 2, Mar./Apr. 1989.
See also
For back EMF shapes other than sinusoidal or trapezoidal, and/or if the stator inductance \(L\) is angle dependent, please use the sophisticated model of the Brushless DC Machine. The sophisticated BLDC machine can be configured as a simple BLDC machine with sinusoidal back EMF if the parameters are converted as follows:
\[K_{\mathrm{c},n} = [0]\]
\[K_{\mathrm{s},n} = [-K_\mathrm{E}]\]
\[L_0-M = L-M\]
\[L_{\mathrm{c},n} = [0]\]
\[L_{\mathrm{s},n} = [0]\]
For machines with sinusoidal back EMF you may also consider to use the Permanent Magnet Synchronous Machine. The parameters can be converted as follows provided that the stator inductance \(L\) is independent of the rotor angle:
\[[L_\mathrm{d} \; \; L_\mathrm{q}] = [L-M \; \; L-M]\]
\[\varphi_\mathrm{m}' = K_\mathrm{E}/p\]
