Translational Speed (Constant)
Maintain constant translational speed
Mechanical / Translational / Sources
../../_images/constanttranslationalspeed.svg
The Constant Translational Speed maintains a constant linear speed between its two flanges regardless of the force required. The speed is considered positive at the flange marked with a “+”.
A speed source may not be short-circuited or connected in parallel with other speed sources, nor may a speed source directly drive a mass.
Second flange
Controls whether the second flange is accessible or connected to the translational reference frame.
Speed
The magnitude of the speed, in \(\left( \frac{\mathrm{m}}{\mathrm{s}} \right)\). The default value is 1.
Force
The generated force flowing from the unmarked flange to the marked flange, in newtons \((\mathrm{N})\).
Speed
The speed, in \(\left( \frac{\mathrm{m}}{\mathrm{s}} \right)\).
