Translational Speed (Controlled)
Maintain variable translational speed
Mechanical / Translational / Sources
The Controlled Translational Speed maintains a variable linear speed between its two flanges regardless of the force required. The speed is considered positive at the flange marked with a “+”. The momentary speed is determined by the signal fed into the input of the component.
A speed source may not be short-circuited or connected in parallel with other speed sources, nor may a speed source directly drive a mass.
- Second flange
Controls whether the second flange is accessible or or connected to the translational reference frame.
- Allow state-space inlining
For expert use only! When set to
onand the input signal is a linear combination of mechanical measurements, PLECS will eliminate the input variable from the state-space equations and substitute it with the corresponding output variables. The default isoff.
- Force
The generated force flowing from the unmarked flange to the marked flange, in newtons \((\mathrm{N})\).
- Speed
The speed, in \(\left( \frac{\mathrm{m}}{\mathrm{s}} \right)\).
