Chopper (Low-Side Switch with Reverse Diode)
Boost converter module with reverse diode
This power module implements a chopper used in boost converters. It offers two configurations:
- Switched
The power semiconductors inside the module are modeled with ideal switches. The switch is controlled with a logical gate signal; it is on if the corresponding gate signal is not zero. For compatibility with the averaged configuration it is recommended to use the value \(1\) for non-zero gate signals.
The module as a whole is modeled with controlled voltage and current sources. The high voltage side of the chopper has current source behavior and must be connected to a positively biased capacitor or voltage source. The low voltage side is typically connected to an inductor. The control input is the relative on-time of the switch with values between \(0\) and \(1\).
In the average configuration the chopper can be operated in two ways:
The control signal is the instantaneous logical gate signal having the values \(0\) and \(1\).
The control signal is the duty cycle of the switch. It is either computed directly from the modulation index or by periodically averaging the digital gate signal over a fixed period of time, e.g. using the Periodic Average block. The averaging period does not need to be synchronized with the PWM and can be as large as the inverse of the switching frequency.
In both use cases, the average implementation supports continuous and discontinuous conduction mode.
Since the duty cycle is simulated accurately even with relatively large time steps, the average configuration is particularly well suited for real-time simulations with high switching frequencies. If the reversed diode is not needed, the alternative chopper module is preferred to minimize model complexity.
The sub-cycle average model implementation requires an internal switching element on the high voltage side. When generating code for the power module the switching element is modeled as either an ideal or non-ideal switch. See Ideal and Non-Ideal Switch Models in Electric Circuits for detailed descriptions of the switch model implementations.
The sub-cycle average implementation cannot model clamping of the high voltage side. Therefore, the applied DC voltage must never become negative.
IGBTandMOSFETfor the symbol the active semiconductor switches. This setting does not change the electrical behavior of the power module in simulation.- Switch model (CPU code generation)
