Half Bridge
2-level half-bridge module
../../_images/igbt_halfbridge.svg
This power module implements a single leg of 2-level voltage source inverter. It offers two configurations:
The power semiconductors are modeled with ideal switches. The individual switches are controlled with logical gate signals. A switch is on if the corresponding gate signal is not zero. For compatibility with the averaged configuration it is recommended to use the value \(1\) for non-zero gate signals.
The module as a whole is modeled with controlled voltage and current sources. The DC side of the inverter has current source behavior and must be connected to a positively biased capacitor or voltage source. The AC side is typically connected to an inductor. The control inputs are the relative on-times of the switches with values between \(0\) and \(1\).
In the average configuration the half bridge can be operated in two ways:
  • The control signals are the instantaneous logical gate signals having the values \(0\) and \(1\).
  • The control signals are the duty cycles of the individual switches. They are either computed directly from the modulation index or by periodically averaging the digital gate signal over a fixed period of time, e.g. using the Periodic Average block. The averaging period does not need to be synchronized with the PWM and can be as large as the inverse of the switching frequency.
In both use cases, the average implementation correctly accounts for blanking times, i.e. when during commutation both switches are turned off. It also supports discontinuous conduction mode, e.g. when charging the DC link capacitor via the reverse diodes.
The sub-cycle average implementation cannot model a shoot-through, i.e. the situation where both switches in a leg are turned on at the same time. Therefore, the sum of the control signals for the upper and lower switch must not exceed \(1\) at any time. Since the DC side is not clamped, the DC voltage must never become negative.
This setting lets you choose between IGBT and MOSFET for the symbol the active semiconductor switches. This setting does not change the electrical behavior of the power module in simulation.
When set to on, the block will flag an error if the sum of the control signals for the upper and lower switch exceeds \(1\).
