Bidirectional Phase-Shifted Full-Bridge Converter
Bidirectional phase-shifted full-bridge converter with optional series capacitor
../../_images/nanostep_bd_psfb.svg
This component implements a bidirectional phase-shifted full-bridge converter with free-wheeling on the low voltage side. A series DC blocking capacitor is optional.
The Nanostep implementation cannot simulate a shoot-through or clamping of a DC link. Therefore, the gate signals for the upper and lower switch in the same leg of the front-end full-bridge must never both become true at the same time. Also, DC voltage must never become negative.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.
Include series capacitor
Allows you to include (yes) or remove (no) the series capacitor.
Series capacitance
A scalar specifying the capacitance of the series capacitor, in farads \((\mathrm{F})\).
Leakage inductance
Leakage winding resistance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
Include magnetizing inductance
Allows you to include (yes) or remove (no) the magnetizing inductance.
Filter inductance
A non-zero scalar specifying the low voltage side filter inductance, in henries \((\mathrm{H})\).
Filter resistance
A scalar specifying the low voltage side filter resistance, in ohms \((\Omega)\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through. When set to off, these errors are not checked during real-time simulation.
The voltage across the series capacitor.
See Fig. 254 for the Nanostep probe signal positions.
Primary current
The current flowing from the front-end DC link into the converter.
Filter current
The current through the secondary side filter inductor.
Snubber current
The current flowing through the snubber switch, from the converter to the low voltage side.
Primary gate signals
Secondary gate signals
Snubber gate signal
The gate signal of the snubber semiconductor switch.
../../_images/nanostep_bd_psfb_probe_signals.svg
Fig. 254 Nanostep Probe Signals for the Bidirectional Phase-Shifted Full-Bridge Converter
