Buck Converter
Buck converter with filter inductance
This component implements a buck converter including the filter inductor. The converter offers two configurations:
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 1, which means it occupies 1/3 of a Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a clamping of the DC input. Therefore, the input voltage must never become negative.
Sub-cycle average, this parameter selects the switch model when CPU code is generated.
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Inductance
A non-zero scalar specifying the filter inductance, in henries \((\mathrm{H})\).
A scalar specifying the winding resistance, in ohms \((\Omega)\).
See Fig. 258 for the probe signal positions.
Fig. 258 Probes for the Buck Converter
The current flowing out of the converter.
The current flowing from the DC link into the converter.
- Gate signal
