CLLLC Converter
Dual active bridge or resonant converter with magnetizing inductance
This component implements an isolated, resonant CLLLC converter. By omitting the capacitors, it can be configured as a dual active bridge (DAB) with magnetizing inductance. If only the primary side capacitor is present, the component can be used as a full-bridge LLC with synchronous rectification or an LLC with secondary leakage inductance.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the applied DC voltages must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.- Primary leakage inductance
A non-zero scalar specifying the transformer leakage inductance of the primary side, in henries \((\mathrm{H})\).
- Primary winding resistance
A scalar specifying the winding resistance of the primary side, in ohms \((\Omega)\).
- Include primary capacitor
yes) or remove (no) a resonant capacitor at the primary side.- Primary resonant capacitance
If the Include primary capacitor option is set to
yes, this parameter requires a non-zero scalar for the resonant capacitance on the primary side, in farads \((\mathrm{F})\).- Magnetizing inductance
- Include secondary inductance
yes) or remove (no) a leakage inductance on the secondary side.- Secondary leakage inductance
If the Include secondary inductance option is set to
yes, this parameter requires a non-zero scalar specifying the transformer leakage inductance of the secondary side, in henries \((\mathrm{H})\).- Secondary winding resistance
A scalar specifying the winding resistance of the secondary side, in ohms \((\Omega)\).
- Include secondary capacitor
yes) or remove (no) a resonant capacitor at the secondary side.- Secondary resonant capacitance
If the Include secondary capacitor option is set to
yes, this parameter requires a non-zero scalar for the resonant capacitance on the secondary side, in farads \((\mathrm{F})\).- Turns ratio
on, the block will flag an error if both gate signals in any of the four half-bridges become true.
The currents flowing into the primary and secondary sides of the transformer.
- Capacitor voltages
The voltages across the resonant capacitors.
See Fig. 259 for the probe signal positions.
Fig. 259 Probes for the CLLLC Converter
The current flowing from the primary DC link into the converter.
