CLLLC Converter with NPC Half-Bridge
Dual active bridge or resonant converter with a primary-side NPC half-bridge
../../_images/nanostep_clllc_npc.svg
This component implements an isolated, resonant CLLLC converter with a 3-level neutral-point clamped half bridge on the primary side. By omitting the capacitors, it can be configured as a dual active bridge (DAB) with magnetizing inductance. If only the primary side capacitor is present, the component can be used as a full-bridge LLC with synchronous rectification or an LLC with secondary leakage inductance.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the combination of logically true gate signals in each inverter leg must never lead to a short circuit on the DC sides. Also, the applied DC voltages must never become negative.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.
Primary leakage inductance
A non-zero scalar specifying the transformer leakage inductance of the primary side, in henries \((\mathrm{H})\).
Primary winding resistance
A scalar specifying the winding resistance of the primary side, in ohms \((\Omega)\).
Include primary capacitor
Allows you to include (yes) or remove (no) a resonant capacitor at the primary side.
Primary resonant capacitance
If the Include primary capacitor option is set to yes, this parameter requires a non-zero scalar for the resonant capacitance on the primary side, in farads \((\mathrm{F})\).
Include secondary inductance
Allows you to include (yes) or remove (no) a leakage inductance on the primary side.
Secondary leakage inductance
If the Include secondary inductance option is set to yes, this parameter requires a non-zero scalar specifying the transformer leakage inductance of the secondary side, in henries \((\mathrm{H})\).
Secondary winding resistance
A scalar specifying the winding resistance of the secondary side, in ohms \((\Omega)\).
Include secondary capacitor
Allows you to include (yes) or remove (no) a resonant capacitor at the secondary side.
Secondary resonant capacitance
If the Include secondary capacitor option is set to yes, this parameter requires a non-zero scalar for the resonant capacitance on the secondary side, in farads \((\mathrm{F})\).
When set to on, the block will flag an error if a combination of gate signals being logically true would short-circuit any of the DC link voltages.
Inductor currents
The currents flowing into the primary and secondary sides of the transformer.
Capacitor voltages
The voltages across the resonant capacitors.
See Fig. 260 for the probe signal positions.
../../_images/nanostep_clllc_npc_probe_signals.svg
Fig. 260 Probes for the CLLLC Converter with NPC Half-Bridge
Inductor currents
Capacitor voltages
Primary currents
The currents flowing into the three DC side terminals of the converter.
Secondary current
Primary gate signals
Secondary gate signals
