Simple Dual Active Bridge
Dual active bridge converter without magnetizing inductance
This component implements an isolated dual active bridge (DAB) converter with an optional resonant capacitor. For a DAB with magnetizing inductance, refer to the CLLLC Converter.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 1, which means it occupies 1/3 of a Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the applied DC voltages must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.- Include resonant capacitor
yes) or remove (no) the resonant capacitor.- Inductance
A non-zero scalar specifying the transformer leakage inductance, referred to the primary side, in henries \((\mathrm{H})\).
A scalar specifying the winding resistance, referred to the primary side, in ohms \((\Omega)\).
If the Include resonant capacitor option is set to
yes, this parameter requires a non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).- Assertions
on, the block will flag an error if both gate signals in any of the four half-bridges become true.
The voltage across the resonant capacitor.
See Fig. 274 for the probe signal positions.
Fig. 274 Probes for the Simple Dual Active Bridge
The current flowing from the primary DC link into the converter.
