3-Phase Dual Active Bridge
Simple 3-phase dual active bridge converter without magnetizing inductance
This component implements an isolated three-phase dual active bridge (DAB) converter with optional resonant capacitors.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the applied DC voltages must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.- Include resonant capacitors
yes) or remove (no) the resonant capacitor.- Inductance
A non-zero scalar or 3-element vector specifying the transformer leakage inductances, referred to the primary side, in henries \((\mathrm{H})\).
A scalar or 3-element vector specifying the winding resistances, referred to the primary side, in ohms \((\Omega)\).
If the Include resonant capacitor option is set to
yes, this parameter requires a non-zero scalar or 3-element vector for the resonant capacitances, in farads \((\mathrm{F})\).- Turns ratio
on, the block will flag an error if both gate signals in any of the six half-bridges become true.
The currents flowing into the primary side of the transformer.
- Capacitor voltages
The voltages across the resonant capacitors.
See Fig. 249 for the probe signal positions.
Fig. 249 Probes for the 3-Phase Dual Active Bridge
The current flowing from the primary DC link into the converter.
