Full-Bridge LLC Converter
Full-bridge LLC resonant converter
This component implements an isolated LLC resonant converter with a full bridge on the input side.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the applied DC voltages must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.- Output rectifier
This setting lets you choose between center-tapped
Half bridgeandFull bridgeoutput rectifier topology.- Leakage inductance
A scalar specifying the resistance of the primary winding \(R\), in ohms \((\Omega)\).
A non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).
on, the block will flag an error if both gate signals in any of the two half-bridges become true.
The voltage across the resonant capacitor.
See Fig. 265 for the probe signal positions.
Fig. 265 Probes for the Full-Bridge LLC Converter
The current flowing from the primary DC link into the converter.
