Full-Bridge LLC Converter with Synchronous Rectification
Full-bridge LLC resonant converter with synchronous rectification
This component implements an isolated LLC resonant converter with a full bridge on the primary side and a half-bridge synchronous rectifier on the secondary side. To realize a full-bridge synchronous rectifier, use the CLLLC Converter component configured without secondary-side capacitance.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the applied DC voltages must never become negative.
- Leakage inductance
- Leakage winding resistance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
A non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).
on, the block flags an error for combinations of gate signals that cause shoot-through. When set tooff, these errors are not checked during real-time simulation.
The voltage across the resonant capacitor.
See Fig. 266 for the Nanostep probe signal positions.
The current flowing from the primary DC link into the converter.
Fig. 266 Nanostep Probe Signals for the Full-Bridge LLC Converter with Synchronous Rectification
