Frequency-doubling LLC Converter
Frequency-doubling resonant LLC converter with synchronous rectification
This component implements an isolated, resonant LLC converter. The input side is modeled as two series-connected half-bridges and the output side as a half-bridge rectifier with synchronous rectification.
The voltage sources connected to the converter must not be short-circuited. Therefore, combinations of switching signals that cause shoot-through of the primary-side DC links are not permitted. Additionally, the DC voltage across a half-bridge must never become negative.
- Leakage inductance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
A non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).
on, the block flags an error for combinations of gate signals that cause shoot-through. When set tooff, these errors are not checked during real-time simulation.
The voltage across the resonant capacitor.
See Fig. 262 for the Nanostep probe signal positions.
- Primary currents
A vector containing the currents flowing from the primary DC links into the converter.
Fig. 262 Nanostep Probe Signals for the Frequency-doubling LLC Converter
