Flyback Converter with Snubber
Flyback converter with leakage inductance and snubber diode
This component implements a flyback transformer with a single output. In addition to the magnetization inductance, the transformer model contains leakage inductances on both the primary and secondary sides. To avoid excessive overvoltages when the switch is turned off, the primary side is equipped with a snubber diode. The diode can be connected to the positive input voltage rail via an RC snubber (resistor in parallel with a capacitor). It is assumed that the snubber capacitance is large enough that its voltage does not change significantly during one switching cycle. The converter offers two configurations:
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Primary leakage inductance
A non-zero scalar specifying the leakage inductance of the primary side, in henries \((\mathrm{H})\).
- Primary winding resistance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
A non-zero scalar specifying the magnetizing inductance, in henries \((\mathrm{H})\).
- Secondary leakage inductance
A scalar specifying the leakage inductance of the secondary side, in henries \((\mathrm{H})\).
- Secondary winding resistance
A scalar specifying the resistance of the secondary winding, in ohms \((\Omega)\).
The current through the magnetizing inductance of the transformer, referred to the primary side.
See Fig. 261 for the probe signal positions.
Fig. 261 Probes for the Flyback Converter with Snubber
- Input current
- Output current
The current flowing into the secondary side of the transformer.
- Switch current
The current flowing into the active semiconductor switch.
- Gate signal
The gate signal of the active semiconductor switch.
