Half-Bridge Inverter
Half-bridge voltage source inverter with filter inductance
../../_images/nanostep_hb.svg
This component implements a half-bridge voltage source inverter including the filter inductor. The converter offers two configurations:
The gate inputs are floating-point numbers with values between 0 and 1 representing the relative on-times of the controlled semiconductors over one simulation step. This technique is suited for real-time simulation on a CPU or a FlexArray solver.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 1, which means it occupies 1/3 of a Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a shoot-through or clamping of the DC side. Therefore, the gate signals for the upper and lower switch must never both become true at the same time. Also, the applied DC voltage must never become negative.
Allows you to chose between Sub-cycle average or Nanostep / Switched configuration.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.
A non-zero scalar specifying the filter inductance, in henries \((\mathrm{H})\).
A scalar specifying the winding resistance, in ohms \((\Omega)\).
When set to on, the block will flag an error if both gate signals become true.
See Fig. 267 for the probe signal positions.
../../_images/nanostep_hb_probe_signals.svg
Fig. 267 Probes for the Half-Bridge Inverter
The current flowing out of the converter.
DC link current
The current flowing from the DC link into the converter.
A vector of the gate signals connected to the semiconductor switches.
