Half-Bridge LLC Converter
Half-bridge LLC resonant converter
../../_images/nanostep_hbllc.svg
This component implements an isolated LLC resonant converter with a half bridge on the input side.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of \(3\), which means it occupies an entire Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch must never both become true at the same time. Also, the applied DC voltages must never become negative.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.
Output rectifier
This setting lets you choose between center-tapped Half bridge and Full bridge output rectifier topology.
Leakage inductance
A scalar specifying the resistance of the primary winding \(R\), in ohms \((\Omega)\).
Resonant capacitance
A non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).
When set to on, the block will flag an error if both gate signals become true.
The voltage across the resonant capacitor.
See Fig. 270 for the probe signal positions.
../../_images/nanostep_hbllc_probe_signals.svg
Fig. 270 Probes for the Half-Bridge LLC Converter
Primary current
The current flowing from the primary DC link into the converter.
Secondary current
