Half-Bridge LLC Converter with Synchronous Rectification
Half-bridge LLC resonant converter with synchronous rectification
This component implements an isolated LLC resonant converter with a half bridge on the input side and a half bridge synchronous rectifier on the output side.
The Nanostep implementation cannot simulate a shoot-through or clamping of the DC sides. Therefore, the gate signals for the upper and lower switch must never both become true at the same time. Also, the applied DC voltages must never become negative.
- Leakage inductance
- Leakage winding resistance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
A non-zero scalar for the resonant capacitance, in farads \((\mathrm{F})\).
on, the block flags an error for combinations of gate signals that cause shoot-through. When set tooff, these errors are not checked during real-time simulation.
The voltage across the resonant capacitor.
See Fig. 269 for the Nanostep probe signal positions.
The current flowing from the primary DC link into the converter.
Fig. 269 Nanostep Probe Signals for the Half-Bridge LLC Converter with Synchronous Rectifier
