Matrix CLLLC Converter
CLLLC converter with 1/2/3/4-phase matrix converter frontend
../../_images/nanostep_matrix_clllc.svg
This help page applies to a set of components implementing isolated, resonant CLLLC converters with a 1-, 2-, 3-, or 4-phase matrix front-end. The topology can be configured as a dual active bridge (DAB) by omitting the resonant capacitors, or as an LLC converter by omitting the secondary-side inductor and capacitor.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to capacitors or voltage sources. The implementation has a weight of 3, which means it occupies an entire Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
Inductive currents must not be interrupted abruptly. Therefore, at all times, the combination of switch signals on the matrix front-end must provide a path for the inductive current of the primary winding. This can be achieved by ensuring that at least one high-side switch and one low-side switch are simultaneously ON in the direction of the current flow.
The voltage sources connected to the converter terminals must not be short-circuited. Therefore, combinations of switching signals that cause phase-to-phase short circuits at the AC front-end or shoot-through of the secondary-side DC link are not permitted. Additionally, the secondary-side DC voltage must never become negative.
Primary leakage inductance
A non-zero scalar specifying the transformer leakage inductance of the primary side, in henries \((\mathrm{H})\).
Primary winding resistance
A scalar specifying the winding resistance of the primary side, in ohms \((\Omega)\).
Include primary capacitor
Allows you to include (yes) or remove (no) a resonant capacitor at the primary side.
Primary resonant capacitance
If the Include primary capacitor option is set to yes, this parameter requires a non-zero scalar for the resonant capacitance on the primary side, in farads \((\mathrm{F})\).
Include secondary inductance
Allows you to include (yes) or remove (no) a leakage inductance on the secondary side.
Secondary leakage inductance
If the Include secondary inductance option is set to yes, this parameter requires a non-zero scalar specifying the transformer leakage inductance of the secondary side, in henries \((\mathrm{H})\).
Secondary winding resistance
A scalar specifying the winding resistance of the secondary side, in ohms \((\Omega)\).
Include secondary capacitor
Allows you to include (yes) or remove (no) a resonant capacitor at the secondary side.
Secondary resonant capacitance
If the Include secondary capacitor option is set to yes, this parameter requires a non-zero scalar for the resonant capacitance on the secondary side, in farads \((\mathrm{F})\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through or interruption of inductive currents. When set to off, these errors are not checked during real-time simulation.
Inductor currents
The currents flowing into the primary and secondary sides of the transformer.
Capacitor voltages
The voltages across the resonant capacitors.
See Fig. 271 for the Nanostep probe signal positions.
Inductor currents
A vector containing the currents flowing into the primary and secondary sides of the transformer.
Primary currents
A vector containing the three-phase currents flowing into the converter.
Secondary current
Capacitor voltages
A vector containing the voltages across the resonant capacitors.
Primary gate signals
A vector for each phase containing the gate signals of the primary side semiconductor switches.
Secondary gate signals
../../_images/nanostep_matrix_clllc_probe_signals.svg
Fig. 271 Nanostep Probe Signals for the 3x1 Matrix CLLLC Converter
