Matrix Phase-Shifted Full-Bridge Converter
Phase-shifted full-bridge converter with 3-phase matrix converter frontend and optional series capacitor
This component implements an isolated phase-shifted full-bridge converter with a 3-phase matrix converter frontend. A series DC blocking capacitor is optional.
Inductive currents must not be interrupted abruptly. Therefore, at all times, the combination of switch signals on the matrix front-end must provide a path for the inductive current of the primary winding. This can be achieved by ensuring that at least one high-side switch and one low-side switch are simultaneously ON in the direction of the current flow.
The voltage sources connected to the converter terminals must not be short-circuited. Therefore, combinations of switching signals that cause phase-to-phase short circuits at the AC front-end are not permitted. Additionally, the secondary-side DC voltage must never become negative.
- Output rectifier
This setting lets you choose between center-tapped
Half bridgeandFull bridgeoutput rectifier topology.- Leakage inductance
- Leakage winding resistance
A scalar specifying the resistance of the primary winding, in ohms \((\Omega)\).
- Include series capacitor
yes) or remove (no) the series capacitor.- Series capacitance
A non-zero scalar specifying the capacitance of the series capacitor, in farads \((\mathrm{F})\).
- Include magnetizing inductance
yes) or remove (no) the magnetizing inductance.- Magnetizing inductance
- Filter inductance
A non-zero scalar specifying the output filter inductance of the rectifier, in henries \((\mathrm{H})\).
- Filter resistance
A scalar specifying the low voltage side filter resistance, in ohms \((\Omega)\).
on, the block flags an error for combinations of gate signals that cause shoot-through or interruption of inductive currents. When set tooff, these errors are not checked during real-time simulation.
The voltage across the series capacitor.
See Fig. 272 for the Nanostep probe signal positions.
- Primary currents
A vector containing the three-phase currents flowing into the converter.
- Filter current
The current through the secondary side filter inductor.
A vector for each phase containing the gate signals of the primary side semiconductor switches.
Fig. 272 Nanostep Probes for the 3x1 Matrix Phase-Shifted Full-Bridge Converter
