3-Phase NPC Voltage Source Inverter
3-phase neutral-point clamped voltage source inverter with filter inductors
This component implements a 3-phase 3-level neutral-point clamped (NPC) voltage source inverter. It includes filter inductors on the AC side. In the model, the DC side and the AC side are electrically isolated from each other. Any electrical connection between the two sides outside the inverter would therefore not reflect the real current and voltage situation and should be avoided. The converter offers two configurations:
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to capacitors or voltage sources. The implementation has a weight of 3, which means it occupies an entire Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a shoot-through or clamping of the DC side. Therefore, the combination of logically true gate signals in each inverter leg must never lead to a short circuit on the DC side. Also, the applied DC voltage must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Inductance
A non-zero scalar or 3-element vector specifying the filter inductances, in henries (\(\mathrm{H}\)).
A scalar or 3-element vector specifying the winding resistances, in ohms (\(\Omega\)).
on, the block will flag an error if a combination of gate signals being logically true would short-circuit any of the DC link voltages.
See Fig. 250 for the probe signal positions.
Fig. 250 Probes for the 3-Phase NPC Voltage Source Inverter
- DC currents
The currents flowing into the DC side terminals of the converter.
The currents flowing out of the inverter.
- Gate signals phase a
The gate signals of the active semiconductor switches of phase a.
- Gate signals phase b
The gate signals of the active semiconductor switches of phase b.
- Gate signals phase c
The gate signals of the active semiconductor switches of phase c.
