Boost PFC Converter
Rectifier with boost converter for power factor correction
../../_images/nanostep_pfc.svg
This component implements a single-phase diode rectifier with a boost converter for power factor correction (PFC). The converter offers two configurations:
The gate input is a floating-point number with values between 0 and 1 representing the relative on-time of the controlled semiconductor over one simulation step. This technique is suited for real-time simulation on a CPU or a FlexArray solver. This implementation cannot handle commutation overlap of the diode rectifier. Therefore, the AC side must not be connected directly to an inductor.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. In this configuration, the DC and AC sides are galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the real current and voltage situation and should be avoided. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 1, which means it occupies 1/3 of a Nanostep solver.
For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a clamping of the DC output. Therefore, the output voltage must never become negative.
Allows you to chose between Sub-cycle average or Nanostep / Switched configuration.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.
A non-zero scalar specifying the filter inductance, in henries \((\mathrm{H})\).
A scalar specifying the winding resistance, in ohms \((\Omega)\).
The current flowing out of the diode rectifier.
See Fig. 256 for the probe signal positions.
../../_images/nanostep_pfc_probe_signals.svg
Fig. 256 Probes for the Boost PFC Converter
The current flowing out of the rectifier.
AC current
The AC current flowing into the converter.
Output current
The current flowing out of the converter.
Gate signal
