Boost PFC Converter with LC Filter
Rectifier with boost converter and LC input filter for power factor correction
This component implements a single-phase diode rectifier with a boost converter for power factor correction (PFC). It includes an LC filter on the AC side. The component offers two configurations:
The gate input is a floating-point number with values between 0 and 1 representing the relative on-time of the controlled semiconductor over one simulation step. This technique is suited for real-time simulation on a CPU or a FlexArray solver. This implementation cannot handle commutation overlap of the diode rectifier. Therefore, the AC side must not be connected directly to an inductor.
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. In this configuration, the DC and AC sides are galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the real current and voltage situation and should be avoided. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 3, which means it occupies an entire Nanostep solver.
For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a clamping of the DC output. Therefore, the output voltage must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Inductance
A non-zero scalar specifying the DC side inductance, in henries \((\mathrm{H})\).
A scalar specifying the winding resistance of the DC side inductor, in ohms \((\Omega)\).
- Filter inductance
A scalar specifying the AC side filter inductance, in henries \((\mathrm{H})\).
- Filter winding resistance
A scalar specifying the winding resistance of the AC side filter inductor, in ohms \((\Omega)\).
- Filter capacitance
A scalar specifying the AC side filter capacitance, in farad \((\mathrm{F})\).
- Filter capcitor series resistance
A scalar specifying the AC side filter capacitor series resistance, in ohms \((\Omega)\).
- DC inductor current
The current flowing out of the diode rectifier.
- Filter capacitor voltage
The voltage across the filter capacitor.
See Fig. 257 for the probe signal positions.
- Filter inductor current
The current flowing into the converter.
- Output current
The current flowing out of the converter.
- Gate signal
Fig. 257 Nanostep probes for the Boost PFC Converter with LC Filter
