Phase-Shifted Full-Bridge Converter
Phase-shifted full-bridge converter with optional series capacitor
../../_images/nanostep_psfb.svg
This component implements an isolated phase-shifted full-bridge converter with an output filter inductor. A series DC blocking capacitor to prevent transformer saturation is optional.
The Nanostep implementation cannot simulate a shoot-through or clamping of the input side. Therefore, the gate signals for the upper and lower switch in the same leg must never both become true at the same time. Also, the input DC voltage must never become negative.
This setting lets you choose between IGBT and MOSFET for the symbol of the active semiconductor switches. It does not change the electrical behavior of the converter in simulation.
Output rectifier
This setting lets you choose between center-tapped Half bridge and Full bridge output rectifier topology.
Include series capacitor
Allows you to include (yes) or remove (no) the series capacitor.
Series capacitance
A non-zero scalar specifying the capacitance of the series capacitor, in farads \((\mathrm{F})\).
Leakage inductance
A scalar specifying the resistance of the primary winding \(R\), in ohms \((\Omega)\).
Include magnetizing inductance
Allows you to include (yes) or remove (no) the magnetizing inductance.
Filter inductance
A non-zero scalar specifying the output filter inductance of the rectifier, in henries \((\mathrm{H})\).
When set to on, the block will flag an error if both gate signals in any of the two half-bridges become true.
The voltage across the series capacitor.
See Fig. 273 for the probe signal positions.
../../_images/nanostep_psfb_probe_signals.svg
Fig. 273 Probes for the Phase-Shifted Full-Bridge Converter
Primary current
The current flowing from the DC link into the converter.
Secondary current
The current flowing out of the converter.
