3-Phase Voltage Source Inverter
3-phase voltage source inverter with filter inductors
This component implements a 3-phase voltage source inverter (VSI). It includes filter inductors on the AC side. In the model, the DC side and the AC side are electrically isolated from each other. Any electrical connection between the two sides outside the inverter would therefore not reflect the real current and voltage situation and should be avoided. The converter offers two configurations:
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. Both sides of the converter have current source behavior and must each be connected directly to capacitors or voltage sources. The implementation has a weight of 3, which means it occupies an entire Nanostep solver. For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a shoot-through or clamping of the DC side. Therefore, the gate signals for the upper and lower switch in each leg must never both become true at the same time. Also, the applied DC voltage must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Inductance
A non-zero scalar or 3-element vector specifying the filter inductances, in henries (\(\mathrm{H}\)).
A scalar or 3-element vector specifying the winding resistances, in ohms (\(\Omega\)).
on, the block will flag an error if both gate signals in any of the inverter legs become true.
See Fig. 252 for the probe signal positions.
Fig. 252 Probes for the 3-Phase Voltage Source Inverter
The current flowing into the DC side terminal of the converter.
The currents flowing out of the inverter.
- Gate signals phase a
The gate signals of the active semiconductor switches of phase a.
- Gate signals phase b
The gate signals of the active semiconductor switches of phase b.
- Gate signals phase c
The gate signals of the active semiconductor switches of phase c.
