4-Phase Voltage Source Inverter
4-phase voltage source inverter with filter inductors
This component implements a 4-phase voltage source inverter (VSI). It includes three filter inductors on the AC side phases. The fourth phase is without filter inductor and is typically connected to the neutral point of the AC system. The converter offers two configurations:
The converter is simulated with time steps in the single-digit nanosecond range. The required Nanostep solver is available exclusively on the RT Box. In this configuration, the DC and AC sides are galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the real current and voltage situation and should be avoided. Both sides of the converter have current source behavior and must each be connected directly to a capacitor or a voltage source. The implementation has a weight of 3, which means it occupies an entire Nanostep solver.
For offline simulation, all power semiconductors in the converter are modeled with ideal switches. The individual switches are controlled with instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is true.
The Sub-cycle average and the Nanostep implementation cannot simulate a shoot-through or clamping of the DC side. Therefore, the gate signals for the upper and lower switch in each leg must never both become true at the same time. Also, the applied DC voltage must never become negative.
IGBTandMOSFETfor the symbol of the active semiconductor switch. It does not change the electrical behavior of the converter in simulation.- Inductance
A non-zero scalar or 3-element vector specifying the filter inductances, in henries (\(\mathrm{H}\)).
A scalar or 3-element vector specifying the winding resistances, in ohms (\(\Omega\)).
on, the block flags an error for combinations of gate signals that cause shoot-through. When set tooff, these errors are not checked during real-time simulation.
See Fig. 253 for the Nanostep probe signal positions.
The current flowing into the DC side terminal of the converter.
A vector containing the abc-phase currents flowing out of the converter.
- Neutral-point current
The d-phase current flowing out of the converter
A vector for each phase containing the gate signals of the semiconductor switches.
Fig. 253 Nanostep Probes for the 4-Phase Voltage Source Inverter
