Netlist File Reference
Import a SPICE netlist from a file at runtime
SPICE Components
This component is an alternative to the Netlist component. Instead of offering a netlist editor holding a hard copy of a previously imported netlist, this component imports netlists at runtime from a referenced file. See Netlist File Reference Component for a comparison against the Netlist component.
The Netlist File Reference dialog consists of five tabbed panes that are described below.
Reference
The Reference tab lets you specify a file, a type and a name for the netlist to be imported.
During the initialization of a new simulation, the .subckt or .model (depending on the selected type) with the given name is automatically imported from the selected file.
The import process works identical to the import functionality of the Netlist component (see Importing Netlists).
File, type and name can be set via variables.
The file path can be absolute, relative to the current .plecs file or relative to any path specified as library search path in the preferences (see Library).
In contrast to the Netlist, detailed diagnostics are not shown. Should there be parsing errors while importing, the simulation will be aborted.
Terminals
In the Terminals tab, you need to define the nodes of the subcircuit that you wish to import. The node names you enter must exactly match those in the imported netlist - order does not matter, but the sets must be identical. An error is thrown if they do not match. For each node, you must specify the name of the corresponding terminal in the schematic.
To move a terminal on the schematic, hold Shift and drag the terminal along the edges of the component.
When importing a .model from a file, the import automatically generates a default .subckt containing a single element using the imported compact model description.
The node names are summarized in the following table.
Model type |
Node names |
Generated statement |
D |
R |
C |
NMOS |
d, g, s |
PMOS |
d, g, s |
VDMOS |
d, g, s |
NPN |
c, b, e |
PNP |
c, b, e |
PJF |
d, g, s |
NJF |
d, g, s |
SW |
+, -, c+, c- |
VSWITCH |
+, -, c+, c- |
Probes
The Probes tab allows you to define probe signals based on the Netlist component’s terminals. In contrast to the Netlist component, only terminal-based probes are available.
You can add parameters here that will be passed on to the imported subcircuit (see (X) Subcircuit Instance Statement). The values of these parameters can be set via variables. The order of these parameters does not matter.
The parameters overwrite parameters defined after params: analog to the Parameters tab of the Netlist component.
It is not necessary to add all parameters defined after params: in the netlist to the table.
Any parameter not specified in the table will use its default value as specified in the netlist.
In contrast to the Netlist component, you can also specify parameters that are not defined after params: in the netlist. Through this netlists that expect to access parameters from an outer scope can be used (see Shadowing).
In this case, the parameter will be passed to the netlist as if it would be listed after params: and a warning is shown.
This must not conflict with a .param definition in the netlist. A redefinition within the netlist always throws an error.
Icon
You can define a custom icon for your Netlist File Reference component via this tab. Details regarding the supported Lua syntax can found in the description of the Mask Icon.
See also
- Using PLECS Spice
How to use PLECS Spice.
- Netlist
Alternative component that allows local in-place editing of a netlist.
- Netlist File Reference Component
Comparison between the Netlist File Reference and the Netlist component.
