Controlling Access to Circuits and Subsystems
PLECS allows you to control user access to individual subsystems or to complete circuits. In particular, you can prevent a user from viewing or modifying a schematic while still allowing the user to simulate a circuit.
To change the access settings of a circuit, open the permissions dialog box by choosing Circuit permissions… from the File menu. To change the settings of a subsystem, choose Permissions… from the Edit > Subsystem menu or the block’s context menu.
You can grant or deny the following privileges:
  • The View privilege controls whether a user can view the schematic of a circuit or subsystem.
  • The Modify privilege controls whether a user can modify the schematic of a circuit or subsystem. For a subsystem it also controls whether the mask definition may be modified.
If you apply access restrictions, you will be asked for a password to prevent an unauthorized person from lifting these restrictions. The access settings can only be changed again if the correct password is provided.
Encrypting Circuits and Subsystems
When PLECS saves a circuit with access restrictions to a model file, it encrypts the respective sections to protect the circuit description from unauthorized access.
