Exporting Schematics
PLECS allows you to export the schematic to a bitmap or PDF file for documentation. The supported image formats are:
  • JPEG (Bitmap)
  • TIFF (Bitmap)
  • PNG (Bitmap)
  • SVG (Scalable Vector Graphics)
  • PDF (Portable Document Format)
To export a schematic choose Export… from the File menu and select your desired output format. A second dialog lets you specify the export options for the specific format, e.g. the bitmap resolution.
It is also possible to copy schematics to other applications directly via the clipboard. To copy an image of the current schematic to the clipboard choose Copy as image from the Edit menu, then select Paste from the Edit menu in your target application.
