Using the XY Plot
The XY plot is used to display the relationship between two signals, x and y. In every simulation step the x and y input signals are taken as coordinates for a new point in the XY plot. You can choose to draw trajectories by connecting consecutive points with a direct line, to draw a vector from the origin to the current point or a combination of both.
../../_images/xyplotscreen.png
Time Range Window  sliders
The time range window allows you to restrict the data that is used for plotting. The window is accessible from the View menu.
The time range can be modified by moving its left and right boundary. The inactive time range is grayed out. By clicking into the time range, the active time range can be shifted without changing its length. Any change of the time range is reflected in the XY plot immediately. If vectors are drawn, the right end of the time range determines the position of the vector head.
If a time range is specified in the XY plot parameters, it is used as the default width of the time range in the time range window. A detailed parameter description is available in the XY Plot documentation.
Zoom, Save View, Export and Print
The XY plot offers the same zoom, export and print operations as the PLECS scope. See section Using the PLECS Scope for details.
