DC Machine
Simple model of DC machine
The machine operates as a motor or generator; if the mechanical torque has the same sign as the rotational speed the machine is operating in motor mode, otherwise in generator mode. In the component icon, the positive poles of armature and field winding are marked with dots.
Fig. 228 Electrical system of a (simple model) DC machine
Induced voltage of the armature winding:
- Armature resistance
Armature winding resistance \(R_\mathrm{a}\) in ohms \((\Omega)\).
- Armature inductance
Armature winding inductance \(L_\mathrm{a}\) in henries \((\mathrm{H})\).
- Field resistance
Field winding resistance \(R_\mathrm{f}\) in ohms \((\Omega)\).
Field winding inductance \(L_\mathrm{f}\) in henries \((\mathrm{H})\).
- Field-armature mutual inductance
Field-armature mutual inductance \(L_\mathrm{af}\) in henries \((\mathrm{H})\).
- Inertia
Combined rotor and load inertia \(J\) in \((\mathrm{Nms^2})\).
- Friction coefficient
- Initial rotor speed
Initial mechanical speed \(\omega_\mathrm{m,0}\) in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
- Initial rotor position
Initial mechanical rotor angle \(\theta_\mathrm{m,0}\) in radians.
- Initial armature current
Initial current \(i_\mathrm{a,0}\) in the armature winding in amperes \((\mathrm{A})\).
- Initial field current
Initial current \(i_\mathrm{f,0}\) in the field winding in amperes \((\mathrm{A})\).
- Armature current
The current \(i_\mathrm{a}\) in the armature winding, in amperes \((\mathrm{A})\).
- Field current
The current \(i_\mathrm{f}\) in the field winding, in amperes \((\mathrm{A})\).
- Rotational speed
The rotational speed \(\omega_\mathrm{m}\) of the rotor in radians per second \(\left( \frac{\mathrm{rad}}{\mathrm{s}} \right)\).
- Rotor position
- Electrical torque
The electrical torque \(T_\mathrm{e}\) of the machine in \((\mathrm{Nm})\).
