Chopper (High-Side Switch with Reverse Diode)
Buck converter with reverse diode and a Sub-cycle average implementation
../../_images/igbt_chopper_highsideswitch_diode.svg
This Power Module implements a chopper with a reverse diode in the high-side switch. It is typically used in buck converters. If the reverse diode is not needed, use the alternative chopper module to minimize model complexity.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging. The high-voltage side of the converter has current source behavior and must be connected to a positively biased capacitor or voltage source. The low-voltage side is typically connected to an inductor.
The power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is non-zero. For compatibility with the Sub-cycle average configuration it is recommended to use the value \(1\) for non-zero gate signals.
The Switched configuration is not recommended for real-time simulations on the RT Box. It is intended for offline simulations that resolve each individual switching event and can serve as a reference for results obtained with the Sub-cycle average configuration.
Selects the component configuration. See the descriptions of Sub-cycle average and Switched above.
