5-Level Half Bridge (ANPC)
5-level active neutral-point clamped half-bridge converter with a Sub-cycle average implementation
This Power Module implements a single leg of a 5-level active neutral-point clamped voltage source converter. It contains eight switches S1 to S8 as indicated in the figure.
Sub-cycle averageEach gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging. The DC side of the converter has current source behavior and must be connected to a positively biased capacitor or voltage source. The AC side is typically connected to an inductor.
Sub-cycle averageconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on the CPU or FlexArray solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.SwitchedThe power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is
non-zero. For compatibility with theSub-cycle averageconfiguration it is recommended to use the value \(1\) for non-zero gate signals.The
Switchedconfiguration is not recommended for real-time simulations on the RT Box. It is intended for offline simulations that resolve each individual switching event and can serve as a reference for results obtained with theSub-cycle averageconfiguration.
Sub-cycle averageandSwitchedabove.- Semiconductor symbol
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Assertions
Sub-cycle averageand this parameter is set toon, the block checks the duty-cycle gate input signals for overlapping relative on-times. It issues aHalf-bridge shoot-througherror if any condition in the following table is met:Gate signal condition
Shoot-through path
\(S_1 + S_2 > 1\)
DC++toDC0\(S_3 + S_4 > 1\)
DC0toDC--\(S_6 + S_7 > 1\)
DC+toDC-\(S_5 + S_8 > 1\)
Invalid flying-capacitor connection
- Switch model (CPU code generation)
Sub-cycle average, this parameter selects the switch model when CPU code is generated.
↳ Added in PLECS 4.4.
