Full Bridges (Series Connected)
Series-connected full-bridge inverter with a Sub-cycle average implementation
../../_images/igbt_fullbridges.svg
These Power Modules implement multiple series-connected inverter cells for use in modular multilevel converters. All control signals as well as the DC side terminals are vectorized with their width matching the number of cells.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging. The DC side of the converter has current source behavior and must be connected to a positively biased capacitor or voltage source. The AC side is typically connected to an inductor.
The power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is non-zero. For compatibility with the Sub-cycle average configuration it is recommended to use the value \(1\) for non-zero gate signals.
The Switched configuration is not recommended for real-time simulations on the RT Box. It is intended for offline simulations that resolve each individual switching event and can serve as a reference for results obtained with the Sub-cycle average configuration.
In Sub-cycle average configuration, the primary (DC) sides of the inverter cells must remain galvanically isolated from each other.
Selects the component configuration. See the descriptions of Sub-cycle average and Switched above.
Number of cells
Number of series-connected full-bridge inverters.
If the Configuration is set to Sub-cycle average and this parameter is set to on, the block checks the duty-cycle gate input signals for overlapping relative on-times. It issues a Half-bridge shoot-through error if the following condition is met:
  • The sum of the gate signals for the upper and lower switches of the same leg exceeds \(1\).
