Half Bridge
2-level half-bridge with a Sub-cycle average implementation
../../_images/igbt_halfbridge.svg
This Power Module implements a single leg of a 2-level voltage source inverter.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging. The DC side of the converter has current source behavior and must be connected to a positively biased capacitor or voltage source. The AC side is typically connected to an inductor.
The power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is non-zero. For compatibility with the Sub-cycle average configuration it is recommended to use the value \(1\) for non-zero gate signals.
The Switched configuration is not recommended for real-time simulations on the RT Box. It is intended for offline simulations that resolve each individual switching event and can serve as a reference for results obtained with the Sub-cycle average configuration.
Selects the component configuration. See the descriptions of Sub-cycle average and Switched above.
If the Configuration is set to Sub-cycle average and this parameter is set to on, the block checks the duty-cycle gate input signals for overlapping relative on-times. It issues a Half-bridge shoot-through error if the following condition is met:
  • The sum of the gate signals for the upper and lower switches exceeds \(1\).
