Boost Converter
Boost converter with filter inductance, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_boost.svg
This component implements a boost converter including the filter inductor.
Both sides of the converter have current source behavior. The high-voltage side must be connected directly to a capacitor or a voltage source.
In Nanostep / Switched configuration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
This component has a Nanostep solver weight of \(1\), indicating that it occupies \(\frac{1}{3}\) of a Nanostep solver for Real-time Simulations on the RT Box.
Selects the component configuration. See the descriptions of Nanostep / Switched and Sub-cycle average above.
See Fig. 259 for the probe signal positions.
DC link current
The current at the high-voltage side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Gate signal
../../_images/nanostep_boost_probe_signals.svg
Fig. 259 Probes for the Boost Converter
