Full-Bridge Inverter with LCL Filter
Full-bridge voltage source inverter with LCL filter on the AC side, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_fblcl.svg
This component implements a full-bridge voltage source inverter including an LCL filter on the AC side.
In Nanostep / Switched configuration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 268.
Selects the component configuration. See the descriptions of Nanostep / Switched and Sub-cycle average above.
Filter inductance
A non-zero scalar specifying the filter inductance \(\mathrm{L_f}\), in henries \((\mathrm{H})\).
Filter winding resistance
A scalar specifying the filter winding resistance \(\mathrm{R_{Lf}}\), in ohms \((\Omega)\).
Filter capacitance
A scalar specifying the filter capacitance \(\mathrm{C_f}\), in farads \((\mathrm{F})\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through.
See Fig. 268 for the probe signal positions.
Filter capacitor voltage
The voltage across the filter capacitor \(\mathrm{C_f}\), in volts \((\mathrm{V})\), defined positive at the side marked with (+).
Filter inductor current
The current through the inductor \(\mathrm{L_f}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
DC link current
The current at the DC-link side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector containing the gate signals of the active semiconductor switches.
../../_images/nanostep_fblcl_probe_signals.svg
Fig. 268 Probes for the Full-Bridge Inverter with LCL filter
