Boost PFC Converter with LC Filter
Rectifier with boost converter and LC input filter for power factor correction, optimized for Real-Time Simulations on the RT Box.
This component implements a single-phase diode rectifier with a boost converter for power factor correction (PFC). It includes an LC filter on the AC side.
Nanostep / SwitchedThe power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is
true.In
Nanostep / Switchedconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Sub-cycle averageEach gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Sub-cycle averageconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on the CPU or FlexArray solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 261.
Nanostep / SwitchedandSub-cycle averageabove.- Switch model (CPU code generation)
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Inductance
- Filter inductance
A non-zero scalar specifying the filter inductance \(\mathrm{L_f}\), in henries \((\mathrm{H})\).
- Filter winding resistance
A scalar specifying the filter winding resistance \(\mathrm{R_{Lf}}\), in ohms \((\Omega)\).
- Filter capacitance
A scalar specifying the filter capacitance \(\mathrm{C_f}\), in farads \((\mathrm{F})\).
- Filter capacitor series resistance
A scalar specifying the filter capacitor series resistance \(\mathrm{R_{Cf}}\), in ohms \((\Omega)\).
See Fig. 261 for the probe signal positions.
- DC inductor current
- Filter capacitor voltage
The voltage across the filter capacitor \(\mathrm{C_f}\), in volts \((\mathrm{V})\), defined positive at the side marked with (+).
- Filter inductor current
The current through the inductor \(\mathrm{L_f}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Output current
- Gate signal
Fig. 261 Probes for the Boost PFC Converter with LC Filter
