Simple Dual Active Bridge
Dual active bridge converter without magnetizing inductance, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_dab.svg
This component implements an isolated dual active bridge (DAB) converter with an optional resonant capacitor. For a DAB with magnetizing inductance, refer to the CLLLC Converter component.
This component has a Nanostep solver weight of \(1\), indicating that it occupies \(\frac{1}{3}\) of a Nanostep solver for Real-time Simulations on the RT Box.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 278.
Primary inductance
Include primary capacitor
Allows you to include (yes) or remove (no) a resonant capacitor at the primary side.
Resonant capacitance
If the Include primary capacitor option is set to yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C}\), in farads \((\mathrm{F})\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through.
See Fig. 278 for the probe signal positions.
Primary current
Secondary current
Primary gate signals
Secondary gate signals
../../_images/nanostep_dab_probe_signals.svg
Fig. 278 Probes for the Simple Dual Active Bridge
