Full-Bridge LLC Converter
Full-bridge LLC resonant converter, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_fbllc.svg
This component implements an isolated LLC resonant converter with a full bridge on the input side.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 269.
Output rectifier
Use this setting to choose between center-tapped Half bridge and Full bridge output rectifier topology.
Primary inductance
Resonant capacitance
A non-zero scalar for the resonant capacitance \(\mathrm{C}\) on the primary side, in farads \((\mathrm{F})\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through.
See Fig. 269 for the probe signal positions.
Primary current
Secondary current
A vector containing the gate signals of the active semiconductor switches.
../../_images/nanostep_fbllc_probe_signals.svg
Fig. 269 Probes for the Full-Bridge LLC Converter
