3-Phase Dual Active Bridge
3-phase dual active bridge converter without magnetizing inductance, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated three-phase dual active bridge (DAB) converter with optional resonant capacitors.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 253.
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Primary inductance
A non-zero scalar or 3-element vector specifying the primary-side inductance \(\mathrm{L}\) per phase, including the transformer leakage inductances and any external series-connected inductors, in henries \((\mathrm{H})\).
- Include primary capacitors
yes) or remove (no) resonant capacitors on the primary-side phases.- Resonant capacitance
If the Include primary capacitors option is set to
yes, this parameter requires a non-zero scalar or 3-element vector for the capacitances \(\mathrm{C}\), in farads \((\mathrm{F})\).- Turns ratio
See Fig. 253 for the probe signal positions.
A vector containing the currents through the inductors \(\mathrm{L}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Capacitor voltages
A vector containing the voltages across the capacitors \(\mathrm{C}\), in volts \((\mathrm{V})\), defined positive at the sides marked with (+).
Fig. 253 Probes for the 3-Phase Dual Active Bridge
