Half-Bridge Inverter
Half-bridge voltage source inverter with filter inductance, optimized for Real-Time Simulations on the RT Box.
This component implements a half-bridge voltage source inverter including the filter inductor.
Both sides of the converter have current source behavior. The DC-link side must be connected directly to a capacitor or a voltage source.
Nanostep / SwitchedThe power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is
true.In
Nanostep / Switchedconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.Sub-cycle averageEach gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Sub-cycle averageconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on the CPU or FlexArray solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
This component has a Nanostep solver weight of \(1\), indicating that it occupies \(\frac{1}{3}\) of a Nanostep solver for Real-time Simulations on the RT Box.
Nanostep / SwitchedandSub-cycle averageabove.- Switch model (CPU code generation)
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Inductance
See Fig. 271 for the probe signal positions.
The current at the DC-link side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector containing the gate signals of the active semiconductor switches.
Fig. 271 Probes for the Half-Bridge Inverter
