Phase-Shifted Full-Bridge Converter
Phase-shifted full-bridge converter with optional series capacitor, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated phase-shifted full-bridge converter with an output filter inductor. A series DC blocking capacitor to prevent transformer saturation is optional.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 277.
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Output rectifier
Use this setting to choose between center-tapped
Half bridgeandFull bridgeoutput rectifier topology.- Include primary capacitor
yes) or remove (no) a DC blocking capacitor at the primary side, to prevent transformer saturation.- Primary capacitance
If the Include primary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C}\), in farads \((\mathrm{F})\).- Primary inductance
- Include magnetizing inductance
yes) or remove (no) the magnetizing inductance \(\mathrm{L_m}\) on the transformer primary side.- Magnetizing inductance
If the Include magnetizing inductance option is set to
yes, this parameter requires a non-zero scalar specifying the magnetizing inductance of the transformer \(\mathrm{L_m}\), referred to the primary side, in henries \((\mathrm{H})\).- Turns ratio
- Filter inductance
A non-zero scalar specifying the filter inductance \(\mathrm{L_f}\), in henries \((\mathrm{H})\).
- Filter resistance
A scalar specifying the filter winding resistance \(\mathrm{R_{Lf}}\), in ohms \((\Omega)\).
See Fig. 277 for the probe signal positions.
- Filter current
The current through the inductor \(\mathrm{L_f}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector containing the gate signals of the active semiconductor switches.
Fig. 277 Probes for the Phase-Shifted Full-Bridge Converter
