CLLLC Converter with NPC Half-Bridge
Dual active bridge or resonant converter with a primary-side NPC half-bridge, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated, resonant CLLLC converter with a 3-level neutral-point clamped half bridge on the primary side. By omitting the capacitors, it can be configured as a dual active bridge (DAB) with magnetizing inductance. If only the primary side capacitor is present, the component can be used as a full-bridge LLC with synchronous rectification or an LLC with secondary leakage inductance.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 264.
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Primary inductance
A non-zero scalar specifying the primary-side inductance \(\mathrm{L_1}\), including the transformer leakage inductance and any external series-connected inductor, in henries \((\mathrm{H})\).
- Primary winding resistance
A scalar specifying the primary-side winding resistance \(\mathrm{R_{L1}}\), in ohms \((\Omega)\).
- Include primary capacitor
yes) or remove (no) a resonant capacitor at the primary side.- Primary resonant capacitance
If the Include primary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C_1}\), in farads \((\mathrm{F})\).- Magnetizing inductance
- Include secondary inductance
yes) or remove (no) a series leakage inductance on the secondary side.- Secondary inductance
If the Include secondary inductance option is set to
yes, this parameter requires a non-zero scalar specifying the secondary-side series inductance \(\mathrm{L_2}\), including the transformer leakage inductance and any external inductors, in henries \((\mathrm{H})\).- Secondary winding resistance
yes, this parameter requires a scalar specifying the secondary-side winding resistance \(\mathrm{R_{L2}}\), in ohms \((\Omega)\).- Include secondary capacitor
yes) or remove (no) a resonant capacitor at the secondary side.- Secondary resonant capacitance
If the Include secondary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C_2}\), in farads \((\mathrm{F})\).- Turns ratio
See Fig. 264 for the probe signal positions.
A vector containing the currents through the inductors \(\mathrm{L_1}\) and \(\mathrm{L_2}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Capacitor voltages
A vector containing the voltages across the capacitors \(\mathrm{C_1}\) and \(\mathrm{C_2}\), in volts \((\mathrm{V})\), defined positive at the sides marked with (+).
- Primary currents
A vector containing the currents at the primary-side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Fig. 264 Probes for the CLLLC Converter with NPC Half-Bridge
