Half-Bridge LLC Converter
Half-bridge LLC resonant converter, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated LLC resonant converter with a half bridge on the input side. For an LLC with a half-bridge synchronous output rectifier, refer to the Half-Bridge LLC Converter with Synchronous Rectification component.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 272.
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Output rectifier
Use this setting to choose between center-tapped
Half bridgeandFull bridgeoutput rectifier topology.- Primary inductance
A non-zero scalar for the resonant capacitance \(\mathrm{C}\) on the primary side, in farads \((\mathrm{F})\).
See Fig. 272 for the probe signal positions.
A vector containing the gate signals of the active semiconductor switches.
Fig. 272 Probes for the Half-Bridge LLC Converter
