3-Phase NPC Voltage Source Inverter
3-phase neutral-point clamped voltage source inverter with filter inductors, optimized for Real-Time Simulations on the RT Box.
This component implements a 3-phase 3-level neutral-point clamped (NPC) voltage source inverter. It includes filter inductors on the AC side.
Nanostep / SwitchedThe power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is
true.In
Nanostep / Switchedconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Sub-cycle averageEach gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Sub-cycle averageconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on the CPU or FlexArray solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
Nanostep / SwitchedandSub-cycle averageabove.- Switch model (CPU code generation)
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Inductance
A non-zero scalar or 3-element vector specifying the inductances \(\mathrm{L}\), in henries (\(\mathrm{H}\)).
See Fig. 254 for the probe signal positions.
A vector containing the currents through the inductors \(\mathrm{L}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- DC link currents
A vector containing the currents at the DC-link side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector for each phase containing the gate signals of the semiconductor switches.
Fig. 254 Probes for the 3-Phase NPC Voltage Source Inverter
