Triple Active Bridge
Triple active bridge converter without magnetizing inductance, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated triple active bridge (TAB) converter with an optional resonant capacitor on the primary side.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 279.
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Primary inductance
A non-zero scalar or 3-element vector specifying the inductances \(\mathrm{L}\), in henries (\(\mathrm{H}\)).
- Include primary capacitor
yes) or remove (no) a resonant capacitor at the primary side.- Resonant capacitance
If the Include primary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C}\), in farads \((\mathrm{F})\).- Turns ratio
See Fig. 279 for the probe signal positions.
A vector containing the currents through the inductors \(\mathrm{L}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Tertiary current
The current at the tertiary-side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Tertiary gate signals
A vector containing the gate signals of the tertiary-side semiconductor switches.
Fig. 279 Probes for the Triple Active Bridge
