Boost PFC Converter
Rectifier with boost converter for power factor correction, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_pfc.svg
This component implements a single-phase diode rectifier with a boost converter for power factor correction (PFC).
In Nanostep / Switched configuration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
This component has a Nanostep solver weight of \(1\), indicating that it occupies \(\frac{1}{3}\) of a Nanostep solver for Real-time Simulations on the RT Box.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 260.
Selects the component configuration. See the descriptions of Nanostep / Switched and Sub-cycle average above.
See Fig. 260 for the probe signal positions.
Input current
Output current
Gate signal
../../_images/nanostep_pfc_probe_signals.svg
Fig. 260 Probes for the Boost PFC Converter
