Frequency-doubling LLC Converter
Frequency-doubling resonant LLC converter with synchronous rectification, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_fd_llc.svg
This component implements an isolated, resonant LLC converter. The input side is modeled as two series-connected half-bridges and the output side as a half-bridge rectifier with synchronous rectification.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 266.
Primary inductance
Resonant capacitance
A non-zero scalar for the resonant capacitance \(\mathrm{C}\) on the primary side, in farads \((\mathrm{F})\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through.
See Fig. 266 for the probe signal positions.
Primary currents
A vector containing the currents at the primary-side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Secondary current
Primary gate signals
Secondary gate signals
../../_images/nanostep_fd_llc_probe_signals.svg
Fig. 266 Probe Signals for the Frequency-doubling LLC Converter
